Old 06-15-2007, 12:30 PM   #11 (permalink)
Originally Posted by Partsguru1 View Post
Yeah Bill, you pretty much described it. All the roads around here (So IL) are have heavy truck traffic, so that may be whats causing the problem. It still is aggrivating though!
Prolly a tire balance issue..........find a place that shaves tires and then balances them "on-car". THAT will fix the problem........guaranteed.
JET
2005 - Silver - A4
Maggie
Dynatech LT Headers
Magnaflow
Volant
Pedders Street II
AP Brake System
Memphis Speakers, Amp, (2) 10" Subs
Kenwood Flip Screen w/nav, dvd, etc.
19" Beyern 5 rims
JHP Gauge Pod
Tuning by RevExtreme - Sarasota
J.E.T. is offline   Reply With Quote
Old 06-15-2007, 10:17 PM   #12 (permalink)
Mine shook, after the dealer said that "aligned" it, car shook worse. New tires, check balance at 2 other places, rotate tires same issue, never got better. Was at the point when I sold it that I couldnt go 50+ without fighting the car
Master Pontiac in Augusta, Ga doesnt think you are good enough to test drive a GTO.
Dont complain about it, they say it is "childish"
They also will not service one when you take it in under warranty.
Tell them what you think at 800-771-0953
Taxman is offline   Reply With Quote
Old 08-05-2007, 01:14 AM   #13 (permalink)
I just drove my car off the lot today . Absolutely amazed by the car. I have noticed that I have what is described here, however. The steering wheel seems to jerk a lot, like in those Rush video games at the arcade. Like... just resistant, sometimes. I checked the air in the tires, upped it a few PSI, and noticed that it's not really there since I drove it right after. But on the high way, around 80+, it begins to get really unsteady. I figured it was just some alignment issue.
Rovalis is offline   Reply With Quote
Old 08-05-2007, 10:02 AM   #14 (permalink)
My Photos: (46)
Welcome to the herd Rovalis....
I would drive the car right back and tell them to correct the problem. Check the inside of the wheels and see if the balancing weights are still there. Could be some came off. The problem you describe sounds like a wheel balance problem. IF this shake is a result of an alignment need, play close attention to the tires for any kind contact with the struts.
You may want to check to make sure the lugs are properly torqued. If it is shaking that bad that would be the first thing I'd check. Also beware of over inflating the tires, keep it at spec reason being, over inflating the front tires will cause the tires to be closer to the struts. There is very little clearance there now as it is.
President : SVGTO Tigers
Member
GTO JUDGE is offline   Reply With Quote
Old 08-05-2007, 06:10 PM   #15 (permalink)
I considered that too, but it doesn't do the usual "oval" feel at low speeds that a balance issue is notorious for. I also noticed that just today, it was doing it ONLY when I was at idle. Stepping on the gas and it doesn't really do it that much. It also STAYS straight, so I outruled the alignment possibility... when I let go of the steering wheel, it just... goes back and forth, but the car stays pretty true to the course that I had when I let go, so I'm thinking it's something along the lines of your thinking, the struts.
