Originally Posted by GTO_400
My 96 Explorer has a hard time getting into reverse (grinding) I'm assuming it's the reverse syncro going south. Has anyone ever replaced a syncro in a trans. before? If so any special tools? I'm also thinking of a low mileage bone yard replacement and sience I'm getting this far into it I'm also going to replace the clutch, pressure plate, & throw out bearing as well.
I wouldn't be sure about it being the gearbox. Unless the thing is really messed up having synchro on reverse shouldn't matter - assuming you only shift into reverse with the truck stopped ( Query - Do these boxes have reverse gear synchro in the first place?)
How does it shift into first? If the clutch is grabbing a little it could make reverse hard to select, but if you have only mild grab you might find that while first might be a little baulky it might not make the same grindinhg noises
If it's grinding with the clutch in, that suggests that the input shaft is still turning so it could be a worn throw bearing or linkages in the clutch mechanism which prevent the clutch from disengaging properly. Try that before you replace the gearbox
