I think that this is where the real problem is with the strut rub issue, Took my GTO an 04 with 29k miles on it for state inspection, took 4 new tires with me because both front were bad with the right front the worst. Dealer found a bad left front tierod and was ready to get me a rental, but found that they had one in stock, they replaced it a performed a alignment under warrrenty due to a bad part under warrenty, I did check out the struts for rub and did see it on both sides, though it did not appear to be causing any tire damage. I did go to a 235/45 tire instead of 245/45, figuring that extra 10mm might help on the rub issue. Right now Ive got 30k on it and everything looks good so far, will keep and eye on it. I did file a report to NHTSA about the rub issue, just to get it on record and I did show it to the dealer who said it was nothing two worry about, yea???
P.S it's amazing that the left tierod being bad cause such bad wear on the right side, again will be monitoring the situtation, OH and the price for the parts is on par for an imported car, It is after all "imported"
