Originally Posted by Russ2005
Local GM dealer parts shop said "absolutely not on a synthetic, do not use anything other than Dexron III which is specified" quote-unquote.
Sounds like a guy trying to make you buy his fluid. The Magnuson-Moss Act makes it illegal for any manufacturer to tie warranty provisions to use of a specific fluid unless they provide you the fluid or they have a waiver on file. Thus the auto manufacturers list specifications for the replacement fluid, not an actual fluid. Any fluid, synthetic or non-synthetic, meeting GM Dexron III standards will absolutely not invalidate your warranty.
And yes, the factory fluid is not synthetic, so in my humble opinion, any synthetic you use will be a vast step up.
GM is learning this lesson and they have recently come out with a new fluid, Dexron VI. From what I've read, to meet the new Dexron VI standard, a fluid will have to be either at least a Group III synthetic, or possibly a Group II/III blend. To the best of my knowledge, no aftermarket company has come out with a fluid meeting the new Dexron VI standard yet. Since AMSOIL uses a Group IV synthetic base stock, I'm sure they'll have no problem meeting the new standard, they just have to formulate one to the proper viscosity requirements of the new fluid.
