Pontiac GTO Pontiac GTO Forum
» Sponsors
» Sponsors
Register Home Forum Active Topics Photo Gallery Search Today's Posts Mark Forums Read
GTOforum.com is the premier Pontiac GTO Forum on the internet. Registered Users do not see the above ads.
Old 07-04-2009, 07:14 PM   #1 (permalink)
tranny/skip shift question
i installed the skip shift eleminator under the passenger side instead of the driver side and i know it is in the wring place i knew so because skip shift still kicks in so my questoin is i cant use a lift nor do i have a jack and jack stands untill monday so is it safe driving it with the skip shift eliminator pluged into the switch on the opposite side?? does any one know what that switch is for?? i just dove for 10 miles and parked it in my garage and can smell something burning is it normal??? .... btw i just purchased the car and the only reason it is intalled in the wrong side of the tranny in because of the cheap instructions and cheap part im ordering an slp one right now
Q8 GTO is offline   Reply With Quote
Old 07-04-2009, 10:30 PM   #2 (permalink)
HP11's Avatar
My Photos: (20)
I'd just remove it and put it on the correct side (as shown in your other thread) and see what happens. I'm sure it will work regardless of the brand if it's correctly installed. I don't know how you can smell something burning and ask if that is normal. It's not. Do a little reaearch before you start installing things. The consequences of not doing research can be costly.....
2005 Cyclone Gray/Black/Manual/17" Wheels,
SLP Skip Shift Eliminator, SLP Lightwieght Skid
Plate, K & N Filter. Clarion DUZ385SAT CD
MP3/USB, 06 Door Lock Button.
HP11 is online now   Reply With Quote
Old 07-04-2009, 10:39 PM   #3 (permalink)
all right thanks for your input but all i needed was what the switch i used did.... any ways the reason why i used the wrong side was because the skip shift i recieved did not fit where it should of so i did a litle search and found a really usefull link
http://www.ttcautomotive.com/English...ice_Manual.pdf
turns out i pegged the reverse lights
Old 07-04-2009, 10:42 PM   #4 (permalink)
ok so this means the burning smell could be the breaks any one else smell breaks?? and im not some dumb backyard grease monkey i am 3 months shy of being ase certified and as most people will say that means nothing .... i instaled it wrong because the insturctions was wrong and the parts i got were wrong
Old 07-05-2009, 06:21 AM   #5 (permalink)
HP11's Avatar
My Photos: (20)
Not trying to pass judgement on your skills at all. Just going with what you said. When did you know the instructions and parts were wrong? Before you installed them? You stated in the other thread that it (the skip shift) was for a different car and you plugged it into the wrong switch.
Old 07-06-2009, 11:50 PM   #6 (permalink)
yessir it had instructions and the plug was round and it was suposed to be sqare so i am asuming it was made for a diferent model 6 speed gm
Old 07-07-2009, 10:05 AM   #7 (permalink)
GTOAA 04-06 Technical Advisor
GTOJer's Avatar
So do you need one? Where are you? This is simple to just tune out...
Jerry
GTOAA '04-'06 Technical Advisor
My Shop
KPE - Klaus Performance Engineering
2004 Pontiac GTO 6.7/M6/Barbados Blue (1 of 271) My Car Page
Featured in the April 2007 High Performance Pontiac Magazine
GTOJer is offline   Reply With Quote
Old 07-07-2009, 06:27 PM   #8 (permalink)
who tunes gto's?? and im in washington
Old 07-08-2009, 12:00 AM   #9 (permalink)
FastFrank's Avatar
Where exactly in WA?
FastFrank is offline   Reply With Quote
Old 07-15-2009, 06:48 PM   #10 (permalink)
fiddler_red's Avatar
Send a message via Skype™ to fiddler_red
Here's all you need:
What is CAGS and how to remove it
fiddler_red is offline   Reply With Quote
Computer guages (Autotap OBDII-CAN Diagnostic) MJGTOWISH 2004-2006 GTO General Discussion 3 12-03-2006 10:01 AM
Shift light question KC.MO.GTO Service, Maintenance and Technical Discussion 1 07-10-2006 09:45 PM
shift knob shaft question purplehaze Drive train, suspension, alignment and brakes. 2 03-01-2006 10:36 PM
Question: How do you shift during normal driving? Rob in CT 2004-2006 GTO General Discussion 14 11-14-2005 02:26 PM
Who is Tremec? jontyrees Service, Maintenance and Technical Discussion 3 04-05-2005 01:27 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
