Old 05-02-2006, 11:15 AM   #1 (permalink)
Ninjured's Avatar
What is that noise???
Sometimes, when I am sitting at a light, I hear this series of 'pops' coming from the right rear. It is about 5 pops and always sounds the same. I am assuming it is normal but what is it? It sounds almost as though someone is knocking on my window....popPOPpopPOPpop
Also, sometimes (fairly rare) when I am letting out the clutch in first (low speed accel.), the rearend makes a noise and the 'low traction' indicator flashes. I have not been able to duplicate on demand and it has done it since the car was new. It has done it in both first and reverse. I have close to 17k miles now
Cow
2005 CGM m6
Ninjured is offline   Reply With Quote
Old 05-02-2006, 07:33 PM   #2 (permalink)
pab13's Avatar
i don't know exactly, but if it sound like its inside the rear 1/4 panel the coil springs could be out of it boot and beyond my expetise to fix. Maybe some dealer could help. Im still look for someone decient, even to get an oil change
pab13 is offline   Reply With Quote
Old 05-03-2006, 11:57 AM   #3 (permalink)
GTOJon's Avatar
WOW...I thought I was crazy. My car has 19,000 miles on it and I've heard that "tap tap tap"......sounds like someone is gently knocking on the rear passenger quarter panel. It used to happen only when I put the car in reverse and I would hear the series of taps/pops just once. Now I occassionally hear them when waiting at a red light. I haven't a clue as to what it is.
Jon
'87 Z28 with mods | '05 GTO - Red on Red A4
GTOJon is online now   Reply With Quote
Old 05-03-2006, 07:40 PM   #4 (permalink)
Holden's Avatar
I've heard that "tap tap tap"......sounds like someone is gently knocking on the rear passenger quarter panel. I hear it when waiting at a red light.
I think it may be somthing to do with gas tank vent system???
Holden is offline   Reply With Quote
Old 05-03-2006, 07:46 PM   #5 (permalink)
Justice's Avatar
Ok, you all have this too?!?!
For me, it happens when torque is applied to the drivetrain. Happens more at low speed, and also sometimes during shifts. I had mine in the shop and they determined it was the crossmember bushing that was making the pooping noise. This is the bushing they unbolt and drop to install the upper insulator bushing for the "thunk-in-the-trunk" TSB.
Let me know if you guys can determine the same.
Justice is offline   Reply With Quote
Old 05-04-2006, 04:31 AM   #6 (permalink)
I think it is a little funny I read this thread before I went to work and when I got out I had the same experience that holden had. I was sitting at a red light and then I heard the tapping from the rear passenger area. I don't know if it matters, but I have an 06 model. What year do you guys have?
socal gto is offline   Reply With Quote
Old 05-04-2006, 10:51 AM   #7 (permalink)
Justice's Avatar
Mine is an 04
Old 05-04-2006, 11:49 AM   #8 (permalink)
GTOJon's Avatar
Mine is an '05.
There was a TSB for a "thud in the trunk"? I heard that once or twice, I just thought it was the body in the trunk.
Jon
Old 05-04-2006, 11:56 AM   #9 (permalink)
Justice's Avatar
Thunk in the Trunk is when you accelerate "aggressively". As you shift, the crossmember get pushed up and thunks into the body. The TSB installs insulator bushings between the crossmember and the body.
Old 05-04-2006, 09:45 PM   #10 (permalink)
ShadesOfGrey's Avatar
Send a message via AIM to ShadesOfGrey Send a message via Yahoo to ShadesOfGrey
That's not true, It's not a launch thing only, cause I get it when I go out and just start the car, a min or two later, knock, knock, knock, and thats before I even put it in gear.
ShadesOfGrey
ShadesOfGrey is offline   Reply With Quote
