Drag springs with lift to get wider tires? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 09-12-2006, 10:21 AM Thread Starter
Has anyone done this? One member posted that with Pedders drag springs with 1 1/2" lift he can put 315's on the rear. I have not heard what rims and offset were used but I am very curious of anyone else knows anything about this and possible setups if you raise the rear ride height.
Any help is greatly appreciated.
mumrah is offline
post #2 of 5 (permalink) Old 09-12-2006, 11:03 AM
Warner Robins GTO's Avatar
I remember reading something similar on another board. But he used drag bags aired up I think to 20psi. He was able to fit 10 inch rim and some 315s..but he stated it was only for the track...that he wouldn't drive around like that.
Edelbrock Shorties, JBA Catless Mids, SLP Underdrive Pulley, LPE AI, Polished TB, CASPER IAT Relocate,Ported Intake Manifold, Magnaflow X-Pipe, Spintech Pro-Street Mufflers, Drag Bags and Nitto Drs.
365hp/365tq Tuned By Vengeance Racing 10-13-2006
Warner Robins GTO is offline
post #3 of 5 (permalink) Old 09-12-2006, 02:11 PM
HTRDLNCN's Avatar
I run the pedders drag springs and 275/40/17s with no problems..
Dont know about 315s , in my case the 275s get the job done just fine.
WWW.HOTRODLINCOLN.ORG
WWW.HOTRODHOLDEN.COM
"Dog Hair Racing"
2004 GTO A4 mostly stock
1.60 60FT
12.005 et
114 mph
1996 F250 Powestroke
16.9
83.3
1972 Oldsmobile 442
HTRDLNCN is offline
post #4 of 5 (permalink) Old 09-12-2006, 02:56 PM Thread Starter
I am currently using Pirrelli 275/40/17 and rolled the fender lip. Definitely going to get the drag springs to help with tire wear.... I have excessive wear on the inside and was told it is due to the squat during acceleration. (do you agree) But I thought GTJoe said he has 315's in the rear and has a slight rub but he has not reposted any additional info.
mumrah is offline
post #5 of 5 (permalink) Old 09-12-2006, 05:34 PM
HTRDLNCN's Avatar
yes,,the inside will wear ifyou are a "spirited" driver because of the squat.
Youll notice with the drag springs how much more traction you will have because its planting the whole tire instead of just the edge.
"Dog Hair Racing"
1.60 60FT
12.005 et
114 mph
16.9
83.3
1972 Oldsmobile 442
HTRDLNCN is offline
Human Verification
