Drag Wheel Setup - Pontiac GTO Forum
post #1 of 7 (permalink) Old 04-10-2011, 02:48 PM Thread Starter
Wagonbacker9's Avatar
Drag Wheel Setup
So, as you can see, I'm new here, I've spent a lot of time over the last few days searching information on drag wheel setups, what fits and whatnot... and it takes forever to find all the info. I'm betting to most of you guys its just given, but for those of us who don't know, I thought it might be helpful to see what does and doesn't work. From what I've gathered I know the following:
Fronts:
04's can clear 15" skinnies
05-06's need to go up to a 17" to clear the brakes
17x4.5 with a 3.5" backspace (stock spare, less backspace will work)
26x4.5x17 tire (185/55/17) (M&H and hoosier are the only makers?)
Rears:
15" will clear all years
Backspacing needs to be:
7.5" for 10" wheels
6 7/8 for 9" wheels
5.5" for 8" wheels
All these backspaces are minimum, and a little more would be better
Max tires on those respective rear sizes are roughly:
275/50/15 (you can go up to a 60 profile for taller)
Roughly equals out to a 26x11.5x15
Maxing this out will require a fender roll, and suspension stiffening, or dropping down to a 255 (10.5) or so.
Am I on track? And I can't find a recommended front tire size anywhere..
Wagonbacker9 is offline
post #2 of 7 (permalink) Old 04-10-2011, 08:20 PM Thread Starter
southeasternfoxbodies has the following info on it:
This is a picture of a 2005 Pontiac GTO with the (Front) 15x3.75 with 1.5” Backspace and 165/80/15 Kumhos
(Rear) 15x10 with 7.5” Backspace and 275/50/15 Mickey Thompson ET Street Radials
What gives?
post #3 of 7 (permalink) Old 04-20-2011, 11:45 AM
I too need to get some traction at the rear! i am pushing 500 RWHP and just spin through first gear and part of second with a 3500 stall. I would also like some opinions on the best laucnch for this car? this is an NA built stroker..
GoatCity is offline
post #4 of 7 (permalink) Old 06-07-2011, 09:48 PM
lowpro192000's Avatar
Would a 15x8 with a 6.5 backspace work?
lowpro192000 is offline
post #5 of 7 (permalink) Old 06-07-2011, 10:19 PM Thread Starter
I'm betting it would cause a lot of clearance issues on the suspension. I'd have to go take a look under my car to see what kind of space there is. With a smaller tire it would probably work.
post #6 of 7 (permalink) Old 06-07-2011, 11:43 PM
I too was thinking of going with a drag wheel combo and had a few questions..first off if you go with different diameters will it miss up the ABS? Do you have to tell the computer your doing it? Also I am assuming you have to lift the back of the car for fender lip clearance?
pnpracing is offline
post #7 of 7 (permalink) Old 06-08-2011, 01:52 PM Thread Starter
The 185/65/15s front matched with 275/50/15's out back are causing the ABS to trip every once in a while, but its not unbearable. when I had the stock tires matched with either pair it did not trip, so if they were a bit closer it likely would not.
As for fender clearance, a fender roll does wonders, I also put in drag bags.
Human Verification
New Drag Setup GTO spares and 17 GTO wheels with M/T ET Streets filmnews Wheels and tires 0 03-02-2011 09:25 PM
whats the 2 rubber plugs at the back rear wheel, wheel well?.... pctek 2004-2006 GTO General Discussion 1 09-28-2010 06:24 PM
What's your alignment settings for your suspension and wheel/tire setup? batmans Drive train, suspension, alignment and brakes. 4 03-17-2010 11:05 AM
drag radials wheel & tire ? matts60gto Wheels and tires 20 12-18-2009 10:24 AM
Suspension Airbag Setup Vs. Regular Suspension Setup MJGTOWISH 2004-2006 GTO General Discussion 8 06-20-2006 09:23 AM
