If your wheels are not hub centric, that is, if your wheels do not have the exact hub size that your vehicle requires, it is easy for your wheels to be mounted on your vehicle slightly off center of your hub. (especially if the installer is using air tools). If your wheels are mounted off center and torqued down, even if correctly balanced, they can cause a noticeable vibration.
Hub centric rings fill any gap between the hub size on your vehicle and the hub void in your wheel so that when they are bolted to the vehicle the wheels are centered on the hub. This helps minimize/eliminates any vibrations do to installation errors.
Do you need them? No, it is possible to mount your wheels and tires without them it’s just harder and can be very frustrating if you want a smooth ride. We give FREE hub rings every set of wheels that we sell.
It is recommended for any installation of wheels that you tighten and torque your lugs by hand and use the proper star installation pattern for tightening and torqueing your lugs.
