If they are glued on, how do you remove the cover to replace a bulb without damaging the lens cover?
If you want to glue it on, I would suggest using clear silicon caulk like what is used to adhere counter tops. It won't be permanent like glue will be so if you have to remove it in the future you can break the bead.
Maybe that is what is used to "glue" the lens on?
President : SVGTO Tigers
Member
