Hello all. I bought my GTO this summer and have always wanted more from the sound system. Tonight I pulled out the carpet from the trunk and realized the holes in my rear deck are empty. No wonder it left me unsatisfied. Up until that point, I was going to get a double din deck and a 10" JL sub to throw it the back. Even though I don't like a ton of bass I thought it would help.
Now that I realize I've been doing without a major piece of my system for so long, I'd like to start with putting something in the rear deck. I've scoured the forum and have seen people suggesting a vast range of audio equipment. The problem is, I know next to nothing about audio stuff.
So, I'm pleading for your help. I just want my stereo to be loud and not distort. I'm not really concerned with tons of heart rattling bass. What should I put in those empty holes?
Also, once I found out my rear deck speakers were gone, I tested the other speakers using balance/fade, and my front and rear speakers are there. I'm not sure how to tell if the tweeters are there or not. Are they visible?
There are no tweeters per se. This system is nowhere near that 'high end'. It sounds like you have everything else that is supposed to be there:
Entertainment Component Views
(1) Front Speaker Assembly
(2) Radio
(3) Subwoofer
(4) Antenna/Rear Defogger Module
(5) Subwoofer Amplifier
(6) Rear Speaker
(7) Anti-Theft Horn
Well, I have everything except number 3. My subwoofers are gone. There's just empty holes with grilles over them in my rear deck. That's what I'm looking to replace. Just not sure what to put in there.
92095171 is the OEM part number if you want stock. And they are generally under 50 each at places like GM Parts Direct or GM Parts Giant, anywhere but the dealer. You could go aftermarket but I foget the ohm rating and size. I've seen that information in threads here, however.
2005 CGM, SLP Skip Shift Eliminator, GMM Ripshift, SLP Lightweight Skid Plate, K & N Filter. Clarion DUZ385SAT,
I think I am going to do aftermarket. Do you think it would be possible to run two 4-ohm 6.5" subs back there? I'm just hoping the stock amp will be able to power them.
Also, I just wanted to say thank you for all the information you've given me. I appreciate it.
I'll let someone with more audio technical knowlege give a proper answer/explaination but personally I'd use 2Ω speakers simply because all of the others are 2Ω.
Also, allow me to add this: The best improvement you can make to the audio in these cars (after you replace the speakers) is to replace the head unit......with just about anything else!!! I know I won't get much argument (if any) on that.
Ah yes that will be done along with the speakers once I choose one. Hopefully I can find a nice one for less than $400. Hoping to replace the shift boot too if I can find a place that sells one that looks like OEM.
There are quite a few good ones out there at that price point. I chose the Pioneer AVH-P3300BT.
__________________ Current: MGW-p, H-pipe, SS OTRCAI, Lovell rear springs, Eliminator shocks and Pioneer AVH-P3300BT.... so far. Next: JBA LTs and catless mids Wish list: Intake, modest cam
