Old 02-11-2008, 09:41 PM   #1 (permalink)
Steering Wheel
Hey Everyone,
I did a search but didn't find what I was looking for.
My "Next" button located on my steering wheel broke. I was wondering if anyone knows how to replace it. I called the dealership and it appears that the entire unit (meaning both sides) is one unit.
I have a feeling that I would need a special tool to take off the steering wheel and that the air bag needs to be taken of as well.
Thanks in advance,
glenn
2005 GTO, PBM, K&N Intake & 3" exhaust
96 LT4 Black/Black, all forged 383 w/ AFR 210 Heads, Vortech T-Trim w/ 12lbs of boost, Blowerworks "Gaseous Intercooling" & Pulley Set, 4.10's, Hurst Shifter, TPIS LT Headers, B&B 3" Exhaust, TPIS 58mm TB
GM_96LT4 is offline   Reply With Quote
Old 02-19-2008, 10:14 AM   #2 (permalink)
zdub's Avatar
Not sure about a special tool....all the airbags I have done are a Torx screw under a little plastic cap. Two screws...airbag comes out and it'll expose a clock spring..unplug and you should be golden. I really don't think you need to take the wheel off, I'll have to check on mine..
04 Torrid Red/Red A4
Pacesetter LTs & midpipes, Magnaflow SpunCats and Dual Magnaflow CB
06 PBM/Black M6
Stainless Works LTs Random Tech Cats and 3" Stainless Works CB
zdub is offline   Reply With Quote
Old 03-02-2008, 01:11 AM   #3 (permalink)
Thanks alot for the info; one last question, I am assuming that the plastic cover is just clipped on?
Thanks again,
Glenn
Old 03-02-2008, 08:31 AM   #4 (permalink)
PEARL JAM's Avatar
Done this before. 1st disconnect your battery. Then remove the air bag. Unfortunatly there is a special tool for this (see pic), but if your handy you can use 2 allen wrenches to "pop" the two left air bag release springs to loosen the left side of the bag, then do the same for the right. Once the bag is out of the way, remove the wheel bolt (see pic). NOTE: this wheel does NOT have a master spline. You can put this wheel back on crooked, so MARK YOUR SPLINES with a sharpie before pulling the wheel. At this point, my wheel pulled right off without the aid of a wheel puller.
Once the wheel is off you will have access to the screws that hold the switches and trim covers on.
2004, .588 lift cam, slp LT's, ported/polished MAF case&throttle body, CAI, Flowmaster Deltas, B&M shortthrow, dragbags, HP Tuners tuned.
PEARL JAM is offline   Reply With Quote
Steering wheel shake Partsguru1 Drive train, suspension, alignment and brakes. 14 08-05-2007 05:10 PM
GTO 6.0 steering wheel emblem 05GOAT 2004-2006 GTO General Discussion 25 05-10-2006 12:18 PM
Steering wheel issues QSGTO Interior Discussions 4 04-18-2006 05:49 PM
take off steering wheel? wannagofast 1964-1974 GTO General Discussion 2 08-01-2005 08:27 PM
65 GTO Steering Wheel fst65gto 1964-1974 GTO General Discussion 0 04-30-2005 08:44 PM
