Go Back   Pontiac GTO Forum > The 2004-2006 GTO > Exterior Discussions
Old 03-19-2008, 10:24 AM   #1 (permalink)
sap fascia mounting hardware
does anyone have or know where i can get mounting hardware for the sap front fascia? i managed to find one, but i need those double ended screws used to hold it on...
jon, 05 CGM
j_evans01@yahoo.com
j_evans01 is offline   Reply With Quote
Old 03-19-2008, 11:37 AM   #2 (permalink)
My Photos: (46)
Hey jon.... Welcome to the forum.
Not sure what double ended screws you need, there are none.
Mounting the front facia:
This is the mounting hardware that comes with the Kit:
Front fascia Extension qty: 1
License plate bracket qty: 1
Pushpins qty: 4
Rivets qty: 2
U-clips qty: 2
screws qty: 2
You will also need 2 sided tape.
The rivets go with the license plate bracket and are drilled into the bumper.
The lower grille is molded into the fascia.
The double sided tape is located on the top edge of the fascia.
The 4 push pins are located on the underside of the front fascia. 1/8" holes are drilled then enlarged to 1/4" for the push pins to press into to secure the bottom of the fascia to the bumper.
The 2 pan head screws are located; one on each side of the front lower fender well. They secure the sides in the fender well.
I have no idea what the U-clips are for, there is no mention of them in the assy process, I am assuming they are for the license plate application.
That is all the hardware there is. There is no double ended screws.
Kind of a long winded answer to your question but I hope the overview will help you.
The push pins are 1/4" in dia. As far as length, you can measure the total thickness of the bumper and fascia and buy accordingly. You may be able to find push pins at a hardware store.
Some time ago there were directions on line for a permanent installment of the front fascia. This encompasses pop riveting it on from behind the bumper and there is what is called a "newly developed attaching screw" There is no further details on that screw but it looks like it screws into a hole and the other end appears to be a rivet.
Vice President : SVGTO Tigers
Member
Old 03-19-2008, 01:39 PM   #3 (permalink)
maybe it's the rivets that i'm looking at. there are approx 8 of them on the back of the fascia that are screwed into the fascia, from what it looks, you drill the holes in the bumper, put the fascia on feeding the rivets through the holes, then secure them from inside the bumper, i'm missing 3 of them, and the double sided tape most likely won't survive a repaint. the other pieces i'm sure the shop can improvise.
jon, 05 CGM
j_evans01@yahoo.com
Old 03-19-2008, 02:04 PM   #4 (permalink)
My Photos: (46)
jon, 05 CGM
j_evans01@yahoo.com
That install was deviated from the "official" installation instructions. As far as the tape, they should have double sided tape on hand. That is just at the top which secures the top portion of the fascia to the bumper. I'm surprised the rivets weren't employed to eliminate the tape procedure. I would think a body shop would be able to improvise an installation for you.
The only thing I wouldn't like is the holes in the bumper from the rivets. If for any reason you want to eliminate the fascia, there will be holes in the bumper. The way the instructions from Pontiac is, you can remove the fascia with no visible holes in the bumper, with the exception of the 4 holes on the underside of the bumper, that you could plug.
Good Luck getting it done.
Member
Old 03-25-2008, 07:51 AM   #5 (permalink)
LOWET's Avatar
My Photos: (5)
Pushpins qty: 4
Rivets qty: 2
U-clips qty: 2
screws qty: 2
Speaking of FASCIA, didn't GM offer a sport version of their front fascia
[ bumper ] . my curent one needs to be repaired and if they have to replace it I might put a different type on the front. Do you know of anyone who offers a different type or style lower front bumper.
THANKS
LOWET is offline   Reply With Quote
Old 03-25-2008, 08:26 AM   #6 (permalink)
My Photos: (46)
The only fascia GM offers that I am aware of is the SAP fascia. Anything other than that is after market.
You can try different parts places for replacement front ends one is...
2005 Pontiac GTO Sport appearance pkg - Parts.com
Member
Old 03-25-2008, 05:49 PM   #7 (permalink)
LOWET's Avatar
My Photos: (5)
THANKS
Another SAP Front Fascia Install (took a few pics) u-got-gto Exterior Discussions 20 05-19-2008 09:01 PM
Need help with sap front fascia texgoat Exterior Discussions 6 05-22-2007 11:37 AM
SAP front fascia extension question dustyminpin 2004-2006 GTO General Discussion 6 01-31-2007 04:46 PM
FS in Austin, TX: New Metallic Black 05 SAP Spoiler and Rear Fascia macdogg 2004-2006 GTO Parts for Sale 0 08-15-2005 09:27 PM
FS in Austin, TX: New Metallic Black 05 SAP Spoiler and Rear Fascia macdogg Southwest 0 08-15-2005 09:20 PM
