For sale is a headlight /engine wire harness from my 68 automatic with hide away lights and a/c. This harness is in good condition , the firewall plug has no corrosion or bent terminals, I have marked 90% of the wires identifying what they are connected to. There are a couple wires unmarked next to the alternator wires that should go to the a/c compressor if you have air, one of the wires also should go to a fast idle solenoid if you have an automatic,the headlight harness is in very good shape and the vacuum harness is also intact. I will also text a very clear wire diagram if needed by buyer. $125.00
