Hello all. 6 years ago I started this project building this 1953 Chevy 3100 5 Window Truck. I just finished it 2 weeks ago. After getting it done, this is really something that should be strictly a weekend warrior/show truck. So I am looking for a possible trade plus cash. Here is some info on the truck:
-All Steel, only the grill, bumpers, front bed panel and tailgate are reproduction.
-Painted Millenium Yellow (dupont base/clear)
-Shave door handles, remote pops doors open and activates/de-activates the alarm
-Frenched in antenna and custom molded LED 3rd Brake light
-LED Taillights in Original style Stainless Steel housings
-Oak bed with stainless strips and hardware.
-Optima battery in bed with billet aluminum mount
-350 early block (casting numbers indicate 69-74 corvette block
-GM forged crank, forged rods, TRW flat tops (10:1 comp)
-Motor is fully studded (ARP)
-Edelbrock Performer RPM Heads
-Comp Cams Pro Magnum Roller Rockers
-Comp Cams Xtreme Energy cam
-Edelbrock Street Tunnel Ram w/ 2 500cfm Edelbrocks hard linked together
-K&N Velocity Stacks
-All MSD Ignition
-Dynomax Coated Headers with Delta Series Flowmaster w/ polished stainless C4 tips under the running boards
-Turbo 350 Tranny, w/ shift kit
-GM 10 Bolt, posi 2:42 Gears
-Summit Rearend Girdle
-Nova Subframe and suspension front and rear
-SSBC Force10 Brakes on all four corners
-Everything Lokar (dipsticks, tranny cables, throttle cable, shifter and E Brake)
-Custom Upholstered Seat
-Interior kit from Rod Doors (custom molded door panels and headliner that matches
-VDO white face gauges w/ Stewart Warner Tach
-Vintage Air A/C system with Polished Sanden Compressor (blows ICE COLD)
-Billet Specialties a/c vents, interior door handles, accessory knobs gas and brake pedals
-14 Gallon aluminum gas tank under the bed
-Custom Aluminum radiator
-Panosonic CD Player w/ 4 6.5” Pioneer Speakers
-17x8 front 17x9.5 rear Torq Thrust II’s with 245/45/17 & 275/40/17 BFG KDWS tires
I only have put 500 miles on this truck, since completion.
This truck looks and sounds incredible, draws more attention than anything else on the street. It’s just too much for how often I would be driving it. I am looking for a Trade of 6 speed preferably 6.0L GTO Plus cash. As good as it looks, pictures don’t do it justice, but here are a few:
