12v+ Keyed IGN source that is also hot while cranking - Pontiac GTO Forum
post #1 of 5 (permalink) Old 02-16-2017, 02:08 PM Thread Starter
So I'm looking for a wire that is hot while key is in the "ON" and "START" position while cranking. I did an LS Swap and the computer loses 12v while cranking so it won't start unless wired to 12v constant. I've tried all of the wires at the ignition switch and couldn't find one. Same at the extra fuse block spade connectors. It is a 66 tempest originally with 350 and 3 speed auto. Also it's factory dash wiring. Any ideas? Thanks in advance!
Dealer369 is offline
post #2 of 5 (permalink) Old 02-16-2017, 06:12 PM Thread Starter
Since the purple or yellow wire in the ignition switch are "on" while cranking (purple goes to starter, yellow went to ignition coil) I was thinking I could use a relay system (see photo) but I don't know if having feedback into the pink wire would be an issue. I suppose I could install a diode to prevent this. Any thoughts?
post #3 of 5 (permalink) Old 02-16-2017, 08:48 PM
Quoted: 4 Post(s)
You could connect a time delayed relay that will apply 12 volts for a few seconds while you start the engine;
https://www.delcity.net/store/Time-D...FdgegQodUOEB8Q
05GTO is offline
post #4 of 5 (permalink) Old 02-17-2017, 11:28 AM Thread Starter
I suppose that could work, but I guess I'm hoping for something a little less elaborate than that. Last night I connected the yellow and pink wire together to and it ended up working to provide power all the time. I'm just worried about feedback into the circuit.
post #5 of 5 (permalink) Old 02-17-2017, 06:15 PM
The coil wire should have 12v anytime the key is on & while cranking
brad900 is offline
Human Verification
12v Ignition source for ignition xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 08-14-2013 05:59 PM
help! Trying to paint ign coils 1320 GTO 2004-2006 GTO General Discussion 6 09-21-2012 08:24 PM
Cost for fixing keyed body panels? PetMyGoat Exterior Discussions 13 06-03-2010 10:24 AM
Constant 12V Source? Musicmike927 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-06-2009 05:52 PM
Plenty of 12v Outlets Now! Xman 2004-2006 GTO General Discussion 10 02-07-2005 05:23 PM
