Another question.
The old frame had the crossmember brackets holding it in. The crossmember is rusted on the ends so is unusable. I was going to reuse the pocket brackets but the crossmember from the new frame has a raised section that won't slide into the brackets so it looks like I'll have to just bolt it to the frame. Should there be rubber insulators between the crossmember and frame?
Thank's in advance.
Allan
