1968 GTO dipstick tube - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 01-01-2013, 09:27 PM   #1 (permalink)
Hi there,
The mechanic forgot to put in the dipstick tube. I have pulled the motor and have the parts ready to go. I just wanted to know if the tube that inserts into the block should be hammered in all the way or not. If so, how do you do that without deforming the hole for the lower portion that goes through the windage tray.
hayes68gto is offline   Reply With Quote
Old 01-01-2013, 09:49 PM   #2 (permalink)
all you need do is put a wood block on it and give it a few good taps (little locktite won't hurt either) to set it in the position you want it (so it comes up between the headers without touching)then the inside one (the windage tray holds it in position). Common mistake to forget to put it in from the inside if they hav'nt worked on Pontiac motors and a lot of the inner tubes get lost during disassembly. I bought one motor where the inner tube was left off and the crank sheared off the end of the dipstick, found it in the pan when i took it apart.
Instg8ter is online now   Reply With Quote
Old 01-01-2013, 11:00 PM   #3 (permalink)
I lost my lower tube when I built mine many years ago...and sheared off the end of my dipstick....and found the piece in the pan on the recent rebuild
No Goat is offline   Reply With Quote
Old 01-02-2013, 12:15 AM   #4 (permalink)
kilkm68's Avatar
My Photos: (10)
That's why I have so much trouble getting the dip stick in my motor!!! I didn't know there was suppose to be a lower tube! Live and learn, thanks forum.
kilkm68 is online now   Reply With Quote
Old 01-02-2013, 11:17 AM   #5 (permalink)
Should the tube go all the way into the block? In terms of the lower piece and the windage tray....it seems like it should....but....it doesn't seem to want to go any further into the block. Any advice??
Old 01-02-2013, 01:47 PM   #6 (permalink)
ppurfield001's Avatar
My Photos: (12)
In order to get the correct reading, you have to keep in mind that on some GTOs, like my 1967 model, there are TWO tubes that hold the dipstick in place. Good luck.
ppurfield001 is offline   Reply With Quote
Old 01-02-2013, 09:58 PM   #7 (permalink)
yep the lower tube directs it to a safe place...
Dipstick tube extension 66goatframeoff 1964-1974 Tempest, LeMans & GTO Technical Discussions 3 09-14-2012 11:37 AM
Oil dipstick tube Icefan71 1964-1974 Tempest, LeMans & GTO Technical Discussions 15 04-20-2012 04:44 PM
Dipstick Tube Replacement Penskecat 1964-1974 Tempest, LeMans & GTO Technical Discussions 6 02-21-2012 04:02 PM
Oil dipstick tube Topkat 1964-1974 GTO General Discussion 3 01-12-2011 05:48 AM
windage tray/dipstick tube wytnyt 1964-1974 Tempest, LeMans & GTO Technical Discussions 1 10-11-2008 05:26 PM
SEO by vBSEO 3.3.2
