1970 gto rear axle fit a in a 1967 lemans?? - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 07-25-2010, 07:07 PM   #1 (permalink)
will a 1970 gto rear axle fit in a 1967 lemans both a 10 bolt axle
bnichols04 is offline   Reply With Quote
Old 07-25-2010, 07:18 PM   #2 (permalink)
jetstang's Avatar
My Photos: (10)
The 70 rear is 5/8" wider per side than the 66/7. I found a 66 rear for my 70 and it sucked the tires right up in the wheelwell, go the other way and tires are in the fenders.
Burning rubber since 1982!!
jetstang is offline   Reply With Quote
Old 08-03-2010, 06:26 PM   #3 (permalink)
would the axle in my 67 lemans be considered a 8.2" gm axle? the tag on it is long gone
Old 08-03-2010, 06:43 PM   #4 (permalink)
My Photos: (473)
If the diff cover is the same as the one pictured it is a BOP 8.2"
05GTO is offline   Reply With Quote
Old 08-03-2010, 06:47 PM   #5 (permalink)
was that the only option in 67 with a 326? could i tell by the vin or anything?
Old 08-03-2010, 08:53 PM   #6 (permalink)
66tempestGT's Avatar
no need for tags. just look at the shape of the cover. particularly the "dips" on each side.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline   Reply With Quote
Old 08-03-2010, 09:40 PM   #7 (permalink)
where can i get a lower ring and pinion ratio? all i can find is 3:55 and higher I just want to rebuild my stock unit but the gears are worn out causing a bang. not sure if i should but a used axle or rebuild mine?? cost plays a big factor here. i am using this to just cruze nothing crazy
Old 08-03-2010, 10:12 PM   #8 (permalink)
jetstang's Avatar
My Photos: (10)
If you can find a highway gear single spin rear for a 66, it shouldn't cost but a couple hundred bucks, just a take out item. To replace the bearings in yours, I don't know, $500? Maybe less, may not be the gears. To rebuild your rear, new gears and Posi is about $1500. You can convert to a 66/7 Chevelle 12 bolt with a conversion U-joint, gain all the plusses of a 12 bolt, but keep the narrow-ness? of the early rear, that is bang for the buck your best bet.
Old 08-04-2010, 10:34 AM   #9 (permalink)
My Photos: (16)
Randy's ring and pinion will sell you a posi carrier for any gear ratio you want. I ordered an Auburn unit, 3:55 gear set and an installation kit, works great.
Restoration pictures password is 'GTO'
Burn-out videos.
Old 08-04-2010, 11:07 AM   #10 (permalink)
xconcepts's Avatar
My Photos: (4)
I'm pulling the rear end off my 66 which is a 2.56 ratio right now and replacing it. Its not originally off a GTO but fit perfect, no tire rub. I will be selling it so if your interested let me know, shipping would be the only pain.
xconcepts is offline   Reply With Quote
67 gto rear axle swap LTGOAT 1964-1974 Tempest, LeMans & GTO Technical Discussions 1 10-20-2009 10:51 AM
1967 Pontiac Lemans wrinkled rear quarter panel Bobfuria1988 1964-1974 Tempest, LeMans & GTO Technical Discussions 2 03-16-2009 07:44 PM
Will a 68-69 GTO front clip fit on a 71 LeMans? team39763 1964-1974 GTO General Discussion 1 10-02-2008 09:44 PM
GTO rear axle Redline Service, Maintenance and Technical Discussion 5 08-16-2004 11:42 AM
SEO by vBSEO 3.3.2
