455 engine upgrade - heads / pistons / compression - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 12-05-2012, 10:08 AM   #1 (permalink)
vera_jr's Avatar
Im looking to upgrade my engine a little. I have a 455 out of a 74 Trans Am in my 69 GTO. Looking at the codes, that is one of the smog engines that was produced in the early 70s. It states that it has a compression ratio of 7.4:1 which is obviously not great. What is the best way to obtain a 9:1 compression ratio with this engine?
New pistons? heads?
vera_jr is offline   Reply With Quote
Old 12-05-2012, 10:38 AM   #2 (permalink)
joesweeting's Avatar
I have a 455 with "96" heads and with that combo I have a 9.5 to 1 comp ratio.
Sent from my ADR6425LVW using AutoGuide.Com Free App
joesweeting is online now   Reply With Quote
Old 12-05-2012, 10:46 AM   #3 (permalink)
vera_jr's Avatar
where did you get the heads? any changes to the pistons?
Old 12-05-2012, 11:37 AM   #4 (permalink)
My Photos: (2)
Pontiacs changed compression ration with cylinder head chamber volume, not piston changes. So, a set of smaller chambered heads will get you where you want to be. I'd recommend no higher than 9:1. There is a good compression ratio calculator for Pontiacs onthe Wallace Racing website.
Old 12-05-2012, 02:00 PM   #5 (permalink)
My Photos: (12)
The general "rule of thumb" is that compression ratio needs to be matched to the fuel --- i.e. 9.1:1 for 91 octane, 9.3:1 for 93, etc.
This is for iron heads and a relatively stock cam. Note that these aren't hard and fast limits, just guidelines. It is possible to push them some, sometimes by a lot - but you have to really know what you're doing and also be willing to invest significant time/coin in building the rest of the engine to do it. In the end, unless it's an a dedicated race motor where every last fraction of power counts, the benefit in terms of increased power usually doesn't justify the cost or the risk involved.
Garland, TEXAS
BearGFR is online now   Reply With Quote
400 v8 compression with 72cc heads SPCMarty 1964-1974 Tempest, LeMans & GTO Technical Discussions 7 05-10-2012 06:06 PM
Engine rebuild help 69 GTO...pistons??? Eshack80 1964-1974 Tempest, LeMans & GTO Technical Discussions 4 03-07-2012 10:58 PM
Lower Compression on 48 heads and SRP pistons jtwoods4 1964-1974 Tempest, LeMans & GTO Technical Discussions 7 02-08-2012 03:53 PM
High compression 455 street engine Thumpin455 1964-1974 GTO General Discussion 50 05-02-2011 06:17 PM
Can '670' Heads work on a 1966 389 engine with stock pistons? Ozzie 1964-1974 Tempest, LeMans & GTO Technical Discussions 10 12-27-2009 12:08 PM
SEO by vBSEO 3.3.2
