Old 04-23-2008, 10:35 PM   #1 (permalink)
65 GTO - limited slip diff oil?
I just changed the rear axle oil on my 65 GTO (w/ limited slip 10-bolt).
I put 85w - 140 (non syn) in it and added a tube of CRC Limited Slip additive.
Seems like the limited slip is not working right anymore...
Do I need to add more friction modifier or did I use the wrong oil?
Does somebody know which oil and how much limited slip additive needs to go in there?
Thanks, Nikolas
nikolas is offline   Reply With Quote
Old 04-24-2008, 06:39 AM   #2 (permalink)
Try 80W or 90W non-synthetic gear oil. Use it in your rear end (The car's rear end I should say) and in your manual transmission (Muncie, Borg Warner, etc)....Eric Let us know what happens.
Eric Animal is offline   Reply With Quote
Old 04-24-2008, 06:55 AM   #3 (permalink)
Moderator
My Photos: (16)
I use the Lucas rear end lube, has the limited slip additive already in it. I like them cause.....they use a pretty blue GTO in their TV add.
To see if the limited slip is working, put two wheels off the side of the road on the gravel and two wheels on the road, take off hard in first gear and both tires should spin.
Old 05-05-2008, 02:51 PM   #4 (permalink)
My Photos: (2)
You'll find that straight 80 weight or 90 weight is no longer available. I recommend using a LIMITED SLIP SPECIFIC gear oil, like Rukee is using, in 85-90W, AND adding the small bottle of LSD additive as well. Consult the manuals....I think the lube is supposed to be GL-4 rated, as opposed to GL-5. Don't run the vehicle with a slipping posi. The 10-bolt has a metallic cone-type clutch that most say an not be overhauled once burnt up. Good Luck.
geeteeohguy is online now   Reply With Quote
TSB Information for 06 GTO Red Bearded Goat 2004-2006 GTO General Discussion 4 06-02-2007 09:00 AM
My Dealership Experience Today in_burrito 2004-2006 GTO General Discussion 43 12-20-2005 05:14 PM
UK's Top Gear reviews the GTO. 1COOLPC 2004-2006 GTO General Discussion 4 08-10-2004 06:18 PM
2005 GTO information Troy Roberts 2004-2006 GTO General Discussion 9 08-05-2004 01:38 PM
