'67 400 Oil Pan Gasket install - Pontiac GTO Forum
post #1 of 3 (permalink) Old 08-23-2008, 06:52 PM Thread Starter
jesserettele's Avatar
We have a 400 that has some aftermarket mods including aluminum heads and has been balanced and blue printed. I am installing an oil pan and heard that if not done correctly/specifically it will end up leaking. Does anyone have the text book answer for installing this oil pan gasket? The oil pan on this one curves up at te front underneath the timing chain cover. Any help would be greatly appreciated.
jesserettele is offline
post #2 of 3 (permalink) Old 08-24-2008, 10:29 AM
Quoted: 35 Post(s)
The service gasket kits often have a two peice oil pan gasket. When changing out a timing chain, you have to replace the front section of the pan gasket. What I've always done: peen the bolt holes on the pan with a ball-peen hammer back into their original shape. The pan has to be FLAT where it joins. Now, use a small amount of GM gasket sealer/slicone and attach the gasket to the pan. Let it set up long enough for the gasket to stay in place, but not cure/set up completely. Add a small bead of sealer at the corners where the timing cover meets the pan and where the crank flange area is. Put a small thin coat of sealer on the block side of the gasket, and install, tightening from the center of the pan in GRADUAL light increments. The number one cause of leaky pans is overtightening bolts and distorting the pan/tearing the gasket. Slow, meticulous, and neat will get'er done. Not TOO much sealer!!!
Jeff
post #3 of 3 (permalink) Old 08-24-2008, 03:26 PM Thread Starter
Thanks, great info!
Human Verification
trans fluid change: who has done it few questions lowazztruck Service, Maintenance and Technical Discussion 3 03-12-2008 03:00 PM
Oil Change Intervals GTO JUDGE Service, Maintenance and Technical Discussion 2 09-30-2007 01:33 AM
Peak Oil Myth Debunked b_a_betterperson The Lounge 3 11-24-2006 11:01 PM
Oil pan cover question. enjracing Drive train, suspension, alignment and brakes. 5 06-13-2006 09:52 AM
laugh for the day 170FC The Lounge 6 10-19-2005 12:29 AM
