67 Front End Suspension - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 03-17-2009, 07:13 PM   #1 (permalink)
Finally got my new carb on (thanks for tellin me to get a Eddy). Now I need to redo my front end. What do you guys recommend? I would like to have some decent handling and stiffness is not a problem. Also I don't want to end up in the poor house!
Bryce
GTO'n'TRANSAM is offline   Reply With Quote
Old 03-17-2009, 07:17 PM   #2 (permalink)
My Photos: (16)
I just used standard stock bushings and ball joints available from NAPA. But poly bushings would give a slight firmer ride.
Restoration pictures password is 'GTO'
Burn-out videos.
Rukee is offline   Reply With Quote
Old 03-17-2009, 07:50 PM   #3 (permalink)
I have to get tie rods and such as well.
Old 03-17-2009, 08:06 PM   #4 (permalink)
worldrocker77's Avatar
Front End Rebuild Kits - Performance Suspension Components
This is where I went to rebuild my front end. Really great guy, knows what he's talking about. I put all urethane bushings in my car. The kit comes with everything you need to rebuild your front end. Good luck!
1969 GTO
Second Owner, 17 years old
Bored out 455, 7k3 heads, turbo 400 tranny with a shift kit.
worldrocker77 is offline   Reply With Quote
Old 03-17-2009, 08:18 PM   #5 (permalink)
67/04gto's Avatar
My Photos: (3)
you prob be cheaper to buy a whoole front end kint from pst or some other suspension company
67/04gto is offline   Reply With Quote
Old 03-17-2009, 08:42 PM   #6 (permalink)
68greengoat's Avatar
I would go with poly's too wherever you can. Makes for better handling..... I replaced my body bushings with poly too. Very happy I did.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline   Reply With Quote
Old 03-17-2009, 11:12 PM   #7 (permalink)
With the right spring and shock combination, you can get a fairly smooth ride with poly bushings. The poly makes for a really good, tight front end.
1969 GTO
Old 03-18-2009, 09:11 AM   #8 (permalink)
My Photos: (2)
I personally use Moog parts, available at NAPA, etc. I don't care for the poly bushings (harshness/vibration/noise), but they will give you stiffer suspension (better handling). I find that as I've gotten a little older, I like to be comfortable on long drives, and to be able to hear and carry on a conversation. I also don't like to knock my fillings out on potholes. I recommend stock rubber bushings , stock suspension components (moog, trw, etc.), and a bigger front anti-sway bar as well as a rear anti-sway bar. Check out the Herb Adams stuff online. If money's no object, you can get tubular A-arms, heim-jointed links, etc. etc. It's up to you.
Old 03-18-2009, 09:49 AM   #9 (permalink)
My Photos: (16)
I'm with you on the ride quality, I like the "like sittin on the couch" ride the stock set-up gives.
Burn-out videos.
Old 03-18-2009, 10:51 AM   #10 (permalink)
These "old guys" and their comfort!
Front end question (71) firecatsrt 1964-1974 Tempest, LeMans & GTO Technical Discussions 1 12-14-2008 09:57 AM
Confused about this forum. dms Drive train, suspension, alignment and brakes. 38 12-12-2008 07:54 PM
Definitive Definition Of Gto Suspension Concerns dms Drive train, suspension, alignment and brakes. 1 12-05-2008 12:47 AM
Report Prompts Investigation Into Pontiac GTO 05GTO In the News 99 06-29-2007 06:13 PM
Front end work GoToIt 1964-1974 GTO General Discussion 1 11-01-2004 01:22 PM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
