Originally Posted by ksucatz
I am in the middle of replacing the bushings in the front a arms of the 72. I figured while I am this far into it, I am stripping the arms and powder coating them and replace the springs. I have been looking at Hotchkis and other sites for spring and they talk about small block and big block springs. There is no difference on the Pontiac. Does anyone have the specs for the front and rear springs from a 72. I seen some from a 67, but this car has to be much heavier in the front. I already had enough problems with the suspension bottoming out. What should the ride height be? I would not mind a firmer suspension setup. Any suggestions would be appreciated.
Brent
Hey Brent,
I did my suspension last winter from end to end. Replaced everything with a PST kit, all urethane.
The old 70 rides like a whole different car.
My buddy that did the work told me before I ordered the stuff, he says: "You know this thing is gonna ride much, much stiffer than before?" And my response was, "I drive a BMW as a dd, can't get much stiffer than that."
Like I said, the 70 rides totally different than before. Tight controlled ride, no bottoming out, doesn't roll over on it's side like it did before. All this for $300 in parts!
As far as the springs, your are correct, no small/big block in a Pontiac. BUT, in 72, didn't they offer a 350 in the LeMans? Maybe that is where he's getting that from.
I would have to look in my restoration guide at home. I seem to remember there being a spring rate chart in there.
Unless someone beats me to it, I'll look when I get home and post it.
Russ
