Originally Posted by Tri-Power
i beleive all we can get from this is it's a 1969 2dr hardtop pontiac GTO assembled in Baltimore MD with a V8.
(unless you sent into PHS)
Somebody correct me if im wrong.
You can't specify which 400 CID engine or transmission was used on this car according to the VIN code, unfortunately the Baltimore plant did not use the accessory coding system which would be listed on the data plate.
I would suggest sending the VIN code to
Pontiac Historical Services along with their fee and they will mail to you the complete billing history and build sheet for the car. They also have available a copy of the window sticker for your car.
