Old 05-23-2008, 10:53 AM   #81 (permalink)
My Photos: (451)
It really looks great and just in time for summer.
Old 05-24-2008, 12:59 PM   #82 (permalink)
Moderator
My Photos: (16)
Thanks 05GTO, if your `66 wasn`t buffed out at the body shop I`d consider the race glaze stuff, it`s kinda slow going, but it does get results. I did another two laps around the car, I`ll post just 1 more pic till I get the top put on. :p
Old 05-29-2008, 08:37 PM   #83 (permalink)
wytnyt's Avatar
rukee
ive seen similar problems many times in the past like this
some are from having lacquer as a bas and even when sanded dowwn it looks ok to shoot over but when new paint hits the surface it actually melts the old paint,,thats where you get most of your adhesion at.
this also will open up any imperfections in the underlying material.
did you use a paint that had a hardener/catalyst with it?
if not the first coats take much longer to cure
also do you know if there was a good quality sealer added before painting?
this can be a necessity especially if the older paint is of a lower or degraded quality as it seals and helps to keep your sanded finish for new paint
i think the reason you see it change and almost go away is the sun is heating the metal ,,,thus causing it to lift away from prior coats.
one other possibility is if a prep cleaner was used prior to painting,,it will actually leave almost a oily residue on the surface causing the paint to go crazy in the wet areas,,,almost like you see streaks like as if you brush painted your car
at any rate the only way is to remove and repaint but i would still make sure a good sealer is used and especially a paint with a hardener / catalyst is used
dont do like i did and painted single stage with no hardener and then got radiator fluid spilled on it from a overhead several months after painting it and it still left little rings in my paint
good luck
wytnyt is online now   Reply With Quote
Old 05-29-2008, 09:14 PM   #84 (permalink)
Moderator
My Photos: (16)
This chemical reaction had nothing to do with old paint. It was cause by the painter putting the base coat on too thick and then covering with the clear before the base coat flashed. He rushed the job and it bit him in the ass. That`s all.
Paint Alternative GTO JUDGE 2004-2006 GTO General Discussion 10 07-19-2007 11:15 PM
'06 Spice Red Paint Problems 10aet2 2004-2006 GTO General Discussion 10 01-19-2006 03:10 PM
Paint Ding Repair SJAndrew Exterior Discussions 5 07-22-2005 01:25 PM
Bad Paint... bemeyer Exterior Discussions 10 04-21-2005 04:15 PM
A Paint By Any Other Name . . . GM Kid 2004-2006 GTO General Discussion 6 03-28-2005 04:42 PM
