Pontiac GTO Pontiac GTO Forum
» Sponsors
» Sponsors
Register Home Forum Active Topics Photo Gallery Search Today's Posts Mark Forums Read
GTOforum.com is the premier Pontiac GTO Forum on the internet. Registered Users do not see the above ads.
Old 07-27-2008, 09:33 AM   #1 (permalink)
rick3452's Avatar
Best oil for 66?
Hi Guys... what do you recomend for oil these days for a 66 with 58K miles??
Thanks in advance....Rick
1966 GTO tri-power 4 speed competition-plus, Tubuler Automotive competition headers. 58 thousand miles. Owned since 1969
rick3452 is offline   Reply With Quote
Old 07-27-2008, 10:11 AM   #2 (permalink)
My Photos: (471)
Rick,
If you are running a stock engine with a flat tappet cam look for an oil that includes zddp, zddp (Zinc Dialkyl Dithio Phosphate) is an additive that enhances lubrication under extreme pressure between the cam and the flat tappet lifter.
Because of emission standards and incompatibility with catalytic converters many of the oil manufactures stoped using zddp in their oils. Shell Rotella heavy duty diesel oil did include ZDDP but I believe they have reduced the levels. I've heard that Amsoil 20W-50 Series 2000 is the only oil that includes additives equal to the ZDDP wear protection.
You can find Extreme Pressure Oil Additives, Eastwood offers ZDDPlus which is an additive for any oil that you decide to use. You may be able to find these additives at some of the auto parts stores.
If you have roller lifters you do not need zddp,
Good luck,
Old 07-28-2008, 06:56 PM   #3 (permalink)
rick3452's Avatar
Thanks!
Old 07-29-2008, 11:51 AM   #4 (permalink)
My Photos: (2)
O5 GTO is absolutely correct. I run Shell Rotella or Delo 400 diesel spec oil with an additional ZDDP additive. The ZDDP was pretty much removed from conventional "car" oils in 2006. Flat-tappet motors have been hating it ever since!
Old 08-02-2008, 09:09 PM   #5 (permalink)
VettenGoat's Avatar
I was told they've also removed it from the Rotella recently .
VettenGoat is offline   Reply With Quote
Oil Change Intervals GTO JUDGE Service, Maintenance and Technical Discussion 2 09-30-2007 01:33 AM
Peak Oil Myth Debunked b_a_betterperson The Lounge 3 11-24-2006 11:01 PM
Oil Analysis FastFreddy Service, Maintenance and Technical Discussion 5 06-10-2006 10:23 AM
laugh for the day 170FC The Lounge 6 10-19-2005 12:29 AM
We're Not Running Out Of Oil b_a_betterperson The Lounge 6 08-24-2005 06:15 AM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
