Fired up my 71 lemans for the first time. Had to cut it short due to a bad coolant leak.
The issue is the tachometer isn't reading steady. It'll try and read correctly but bounces around and drops to zero for a bit.
I have the crane cams xr-I conversion installed without the ballast. I also don't have the tach's lighting wire hooked up.
Any one have ideas why it's doing this?
Good news is it fired up easy once it had gas.
Sent from my iPhone using Autoguide.com App
