Camshaft problem Need person in the know!
I'm just rebuilding a 1969 Pontiac Gto with Ram air 3 Heads and i'm trying to get the correct cam for the engine. I've been told by a local rebuilder (im in Australia, and he hasnt done one before)
these are the came specs that he recommended
(I would like the peak power to be around 5300rpm like a ram air 3 GTO)
Precision Cams CM428D
Lobe Spread -112
Lobe centres -Exh 116 Int 108
Cam lift - Exh 296 Int 281
Valve Lift - Exh 444 Int 422
SAE duration EXH 288 Int 276
SAE overlap 59
.050 Duration Exh 214 Int 204
0.50 Overlap -15
Lash Exh hyd Int Hyd
Any help would be great as where i live there arent any people around that know anything about pontiac 400's
Thanks Heaps Guys
