i bought a set of cast heads date code k129 and j149. the casting #16 with small valves (1.96 int, 1.66 ext). looking at hp ratings, #16 large valves 2.11,1.77(330,335,350,366hp?)
http://www.pontiacpower.org/cgi-bin/head.cgi are up there with the #12,#13, and#48(all around 350hp). the flow numbers were one of the best tested for stock heads.
http://www.pontiacpower.org/ultimatehead.htm
my question is 1).do the small valve heads flow the same as large valve? 2).has any one taken small valve heads and machined them for large valves? 3). I was looking at the edlebrock heads and they have 2.11 intake and 1.66 ext., would it make sence to machine the cast heads to match the E-heads? i was told the runners would be miss matched?
