You can find good used early covers. If you go to a late style, you will have to change all of your pulleys, as the belt alignment will be off. Big hassle. If the cover is pitted or corroded severely, it needs replacing anyway. Replace the cover and re-check the system. If it ain't the cover,it could be head gaskets, cracked head, or a cracked block. Do the obvious first....replace/repair the cover.
