Old 05-19-2008, 11:15 AM   #1 (permalink)
Correct Radiator for a 65, 389, Tri Power?
I am looking for information regarding the correct radiator for a 1965, 389 Tri Power as related to the filler neck position.
I need a new radiator for my numbers matching car and want to make sure I get the proper one.
My car currently has a right side (Passenger side) radiator. The Year One catalog states that the tri power radiator should have a left side (DRIVER SIDE) filler neck. The Year one catalog has had errors in the past related to the fan guard, for this year and motor configuration, so I am looking for confirmation on the proper configuration.
I have asked numerous "Experts” and have numerous answers.
I have reviewed the information the GM shop manual and it does not provide information related to the actual position of the filler neck.
Can anyone tell me where I can get a definitive answer to this question?
KINGARTHURV1 is offline   Reply With Quote
Old 05-19-2008, 11:41 AM   #2 (permalink)
Moderator
My Photos: (16)
Welcome to the forums.
I have a `65 Tri-Power car as well. The upper hose is on the right (passanger) side. Mine has the fan shroud, but not the guard on top. I was told they had either the guard or the shroud. Also it was replaced before I got the car with a 4 row, but the 3 row is correct for a non-A/C car I believe. The Parts Place shows the radiator you need, give them a call they are awesome. I`m not sure if mine is 100% correct, but sept for the 4 row, so if anyone else could chime in to say one way or the other, it would be great.
http://thepartsplaceinc.com/ocatalog...&YearList=1965
Old 05-19-2008, 02:18 PM   #3 (permalink)
Thanks for the quick reply!
I live very near Year one and they do have the Radiator with the right side filler neck available, it is just the question regarding the correctness of their catalog in stating that the left side filler neck is the correct one.
Do you have any idea where I can get the factory specifications that would show the correct configuration?
Old 05-19-2008, 04:09 PM   #4 (permalink)
Moderator
My Photos: (16)
I would call The Parts Place Inc. dot com through that link I posted above, they will tell you which is correct for your car. I see they list 3 and 4 row with filler necks on both the left and the right, with and without A/C and auto trans.
Old 05-19-2008, 04:33 PM   #5 (permalink)
My Photos: (2)
My Factory tripower '65 has the original (recored twice) 4-row Harrison Radiator. ALL tripower cars came through with a 4 row radiator originally. 3 row was not offered with the 3x2 setup. The filler neck is on the top tank, fairly close to the middle. I forget which side it's closer to: I'll have to look! It's not a cross flow radiator, which have filler necks on either side. The Upper hose is on the passenger side of the car, and the core support is wider to accomodate the thick lower tank.
Old 05-19-2008, 04:48 PM   #6 (permalink)
Thanks,
I called and they cannot give me any information regarding which of the options should be used. They have both configurations but no information on how to determine which is proper for my car..........
Same issue I have run into before. Hopefully some one will read my request and shed some light on the solution.
Thanks for all your help!!
Old 05-19-2008, 10:04 PM   #7 (permalink)
My Photos: (451)
Rukee's radiator appears to have the correct filler location for a 65 3X2 setup, I purchased a guard from Ames Performance for the top of my 66 radiator and their catalog states the Fan Guard (P146Y) is for years 64 - 67 (except 65 tri-power) which uses Fan Guard (P147)
P146Y has the filler cap located a few inches toward the drivers side while the P147 is toward the passengers side.
This information is on page 197 of the Ames Catalog which you can download here.
05GTO is offline   Reply With Quote
Old 05-21-2008, 08:57 AM   #8 (permalink)
Thanks Guys,
The car had a passenger side filler neck when I purchased it and after looking a quite a few 65 "High Dollar" restorations for sale on the net, I am convinced that the one in the cat is correct. It is a bit frustrating that I cannot find any GM documentation stating the original specifications for this power plant configuration.
Thanks for you time in responding to my request!!
Solar power fergyflyer The Lounge 5 04-18-2008 10:17 PM
Need 389 Tri Power Highskool Engine Discussions 0 09-09-2006 06:21 PM
