Cutting and Welding - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 01-15-2013, 06:53 PM   #1 (permalink)
joesweeting's Avatar
Cutting and Welding Question
I'm almost finished replacing the front passenger side floor pan.
I also need to replace the floor pan on the drivers side. However, the fuel and brake lines run along that side of the vehicle. The best course of action would be to remove all lines.
I would prefer not to since there is a chance of them breaking. I want to cut the half closest to the lines with a cutting wheel and then use the plasma cutter for the rest. I was going to place extra welding leathers on the lines during cutting and welding.
Has any one done this before?
Sent from my ADR6425LVW using AutoGuide.Com Free App
joesweeting is online now   Reply With Quote
Old 01-16-2013, 10:13 AM   #2 (permalink)
My Photos: (16)
I replaced both floor pans, and trunk pan without doing anything to the lines.
Restoration pictures password is 'GTO'
Burn-out videos.
Old 01-16-2013, 04:01 PM   #3 (permalink)
Thanks, what did you use/method to cut the floorpans? What did you use/method to weld the floorpans? How much of the floor pan did you replace?
Old 01-16-2013, 05:17 PM   #4 (permalink)
My Photos: (6)
Yeah, I've done the same on many different cars. I use a thin cutoff wheel and mig weld in place. Lots of wet rags and leather or sheet metal to shield the lines.
ALKYGTO is online now   Reply With Quote
Old 01-16-2013, 05:22 PM   #5 (permalink)
My Photos: (16)
Like Alky I used the thin cut off wheels to remove the floor. I did the whole bottom and up the sides about two inches. I overlapped the new over the old by about an inch. I stich welded with a wire feed all the way around untill the whole thing was welded. I then used some seam sealer over the welds. For the floor braces I used a spot weld remover and then drilled 1/4 inch holes in the floor pan and welded the floor to the braces filling the holes.
Burn-out videos.
Old 01-16-2013, 07:20 PM   #6 (permalink)
Thanks for the info guys.
Autobody Welding and Sheet Metal Fab. Tips/ Tricks Ranger01 1964-1974 Tempest, LeMans & GTO Restoration Discussions 82 04-25-2013 09:06 AM
welding, welding and more welding bobby326 1964-1974 Tempest, LeMans & GTO Restoration Discussions 17 12-21-2012 08:56 PM
spary welding eou_edu@yahoo.com 1964-1974 GTO General Discussion 3 04-16-2010 02:19 AM
Cutting off Cats? AlanSr Intake and Exhaust Discussions 3 11-12-2009 09:26 PM
Miller Auto Darkening welding helmet WS6Vert General Classifieds 1 02-22-2007 09:05 AM
SEO by vBSEO 3.3.2
