Dwell adjustment
As a prelude to my starter replacement, I was adjusting the dwell on my Goat. Twice in 3 weeks, it had drifted from 30 degrees to 20 degrees ... first was after the 400 + mile trip to PA for the fourth, and the second was after returning. Both times, it didn't seem to have the power it should have had, so I checked the timing and found the dwell had drifted. This has raised a couple of questions...
1. When I get a dwell angle I'm happy with, and the goat is happy with, should I put some loctite on the screw threads?
2. I currently have the dwell set to 31.5 degrees, and have a marked improvement in performance (I can light up the back end on a 1-2 shift every time now, not just on certain types of pavement) but the tradeoff is that it's a bit harder starting now, and I can't seem to get a good idle speed (cold or hot). Is this a carburetor issue or a ignition timing issue?
possibly pertinent info: 1970 400, Holley 650, initial timing at 12 deg BTDC @800 RPM. current best idle: 650 RPM
