Electrical Wiring Nightmare - Pontiac GTO Forum
post #1 of 2 (permalink) Old 06-17-2017, 07:44 AM Thread Starter
I am hoping that someone may be able to help me, I have a 1970 GTO,
It was originally a 400 with th400 auto. It currently has a 1974 Chevrolet 350 engine with what i believe is the original th400.
I am trying to find someone in the metro Cincinnati area that has performed electrical work in the past. The car is in pretty rough shape, It was rewired with a different wiring harness from a completely different car and spliced into the existing harness. This left a mess of cut wires, taped wires, wires going no where and leaving me with a lot of questions. I have got the car running using a test switch and direct running wires to the battery and starter. I need to find someone locally to help me install a new engine wiring harness and under dash harness or to do the installation themselves. I am hopeful to get a this GTO back on the road..
Any help would be greatly appreciated..
Thanks!!
ID:	92225   Click image for larger version
PSYCHODAD69 is offline
post #2 of 2 (permalink) Old 06-19-2017, 12:03 PM
64GTOConvertible's Avatar
I'm in the process of getting my 64 running with all new harnesses. It isn't as hard as some make it out to be, especially if you have the luxury of existing wiring to help you figure it all out. Get a wiring diagram for your car and mark each plug and socket as you remove them. Lay the whole mess out on a table and match up as much as you can with the new harness. The manual should help figure out the hacks previous owners did.
64GTOConvertible is offline
Human Verification
Electrical Nightmare greyfellas 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 04-09-2017 05:36 PM
1967 GTO electrical wiring issues grrrr67gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 07-23-2014 07:00 AM
some wiring/electrical questions virginiavenom 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 08-09-2011 04:36 PM
GTO's nightmare! Aramz06 The Lounge 5 08-16-2008 07:49 PM
What a nightmare! Rukee The Lounge 2 12-26-2007 03:09 PM
