Ok here’s the deal.
I’ve got a 67 GTO with a 455. I’m running a Milodon water pump, March serpentine belt setup, Be Cool radiator, the engine is set up for the street with a Comp Cams 51-224-4 , Edelbrock aluminum intake and Hooker super comp headers.
Here’s the problem
No mater what I do it will not run below 220/230 degrees under any circumstances in the summer when using electric fan/fans/shrouds/ect. It won’t idle at 180 in winter. I’ve tried using the Griffin radiator, dual fans pulling or pushing, single 2000 cfm fan with or with out shroud. I’ve added Water Wetter and even tried an air dam under the radiator support and removing the thermostat.
Never any difference!
Finally :
I switched back to the factory belt driven fan and shroud. Ta daaa! The engine now heats up promptly to 180 and stays right there. Only thing is…now I sound like a flipping
C-130 taking off every time I wind out 1st gear. Is there no justice? I don’t remember the factory stock Pontiacs sounding like that.
What gives?
