Fan and Fan Clutch - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 11-19-2012, 09:11 AM   #1 (permalink)
jtwoods4's Avatar
My Photos: (10)
Fan and Fan Clutch
Can someone reccomend a good radiator fan and clutch for a 69. I am installing a high performance engine and I want to make sure it is cooled correctly. Not interested in electric fans, just need a reccomendation for a good aftermarket fan for a high performance engine.
-JW
jtwoods4 is offline   Reply With Quote
Old 11-19-2012, 10:48 AM   #2 (permalink)
My Photos: (12)
In truth, for an engine-driven fan system it's pretty tough to do better than the original factory fan and clutch, properly installed with the shroud.
Garland, TEXAS
BearGFR is online now   Reply With Quote
Old 12-07-2012, 07:47 PM   #3 (permalink)
gtoearl's Avatar
I have a 66 gto that has a clutch fan setup.. My problem is that there is a little wobble when running...I think it actually have weird sound coming from the engine that's driving me nuts....does this make sense.?...Is it the clutch or the fan.....How can you tell so you don't have to by both to solve the problem...........thanks
gtoearl is offline   Reply With Quote
Old 12-10-2012, 12:55 AM   #4 (permalink)
My Photos: (12)
If it's wobbling, my first suspicion would be the fan clutch. When they fail, one of the ways they can fail is they can come apart and allow the fan to spin loose inside the engine compartment. It's not pretty...
With the engine off, grab it and see if you can move it around with your hands. You ought to be able to tell where the looseness is that way - the clutch or the water pump shaft.
Garland, TEXAS
Old 12-14-2012, 02:07 PM   #5 (permalink)
gtoearl's Avatar
I check it....There is a little, very slight movement...Can't really tell if it's the clutch or the water pump... I'm inclined to think it's the clutch as the engine has about 4000 at best miles on it from it's overhaul. I'm guessing it doesn't take much give or movement to create a wobble.....
thanks so much for your several responses to my issues,,,Bear
Installed Tick clutch master. Clutch pedal feels different. SplitFire Drive train, suspension, alignment and brakes. 12 01-18-2012 05:15 PM
Clutch goes soft after driving spiritedly and other clutch related things Sciggy Drive train, suspension, alignment and brakes. 11 04-02-2011 01:01 PM
LS7 clutch vs Monster Level 2 clutch POLGTO05 Drive train, suspension, alignment and brakes. 5 05-26-2010 07:18 PM
SEO by vBSEO 3.3.2
