Pontiac GTO Pontiac GTO Forum
» Sponsors
» Sponsors
Register Home Forum Active Topics Photo Gallery Search Today's Posts Mark Forums Read
GtoForum.com is the premier Pontiac GTO forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 12-21-2008, 05:35 PM   #1 (permalink)
TC71Lemans's Avatar
Freeze Plug Leak Pontiac 350
I just recently bought my 1971 Lemans Sport Convertible and have noticed there is a slow coolant leak from the passenger side freeze plug on the end of the cylinder head near the firewall. Can this freeze plug be replaced by a mechanic without pulling the motor or removing the head? Not sure exactly how "slow" this leak is because of non-stop snow since I got my new toy here. Maybe I don't need to be in rush to fix this?
Thanks, Dave
Traverse City, MI
TC71Lemans is offline   Reply With Quote
Old 12-21-2008, 06:13 PM   #2 (permalink)
ppurfield001's Avatar
My Photos: (12)
Thanks, Dave
Traverse City, MI
Dave -- I am having some engine work done on my 1967 GTO 400 cid engine and one of the things to be done is to install brass freeze plugs, which are better than the factory freeze plugs. My engine has been pulled, making everything accessible. I would replace the freeze plugs with brass plugs if I had the opportunity. Good luck, Paul.
ppurfield001 is offline   Reply With Quote
Old 12-22-2008, 12:17 PM   #3 (permalink)
My Photos: (2)
Dave, by all means, FIX it!!! Coolant leaks and Pontiacs don't mix. If you dont want to pull the motor, etc. , here's how: take a "ladyfoot" type of small crowbar and pry/knock out the old freeze plug. You can knock or pry it into the water jacket, but you will then have to pull it out. It will be rusty and pper thin. Now, go to the auto parts store and get a matching RUBBER freeze plug, the kind that is a rubber puck between two washers, with a nut and stud going thru it. You slip it into the back of the head or block, and tighten the nut. Easy, and will last for years. But, if ONE plug is leaking, the others are sure to follow!!! Brass is my favorite as well. Good luck!
Pontiac tries high-performance revival Wing_Nut In the News 16 03-27-2008 07:43 PM
69 Judge-need your opinions, please joeflyer 1964-1974 GTO General Discussion 11 08-03-2006 12:24 AM
Pontiac Celebrates Racing 'Triple Crown' 05GTO In the News 0 11-17-2005 09:52 PM
GM's Plan To Save Pontiac And Buick 05GTO In the News 6 06-01-2005 07:52 AM
Pontiac tries to revive brand 05GTO In the News 2 02-25-2005 06:10 PM
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
