Ignition switch 69 gto problems - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 11-25-2010, 09:42 AM   #1 (permalink)
I replaced the ignition switch but cannot get any power. Lights don't work, radio, etc. I have played around with the position of the switch on the column by moving it a little each way but when I turn the key still nothing. One time it did get power and car started but then back to nothing. I have tried moving the rod coming off the ignition to different positions in the switch (sliding adjustment on switch) but still no good. Very frustrated. Any suggestions?
dbocquin is offline   Reply With Quote
Old 12-09-2010, 02:50 PM   #2 (permalink)
Sounds like a "serious problem"! I'll take the car off your hands
In all seriousness, it could be a number of things. I would "ohm out" the switch in the various positions to make sure the switch is operating correctly. If the switch is good, then its most likely the wiring back to the fuse panel or bulkhead connectors. Good luck.
Scooter is offline   Reply With Quote
Old 12-09-2010, 08:39 PM   #3 (permalink)
If the switch is still in the car it might be easier to use a test light instead of the ohm meter.
dimitri is offline   Reply With Quote
Ignition Switch issues on 04- 06 GTO?? Smokin'Goat Service, Maintenance and Technical Discussion 3 05-03-2010 06:19 PM
new ignition switch BillGTO 1964-1974 Tempest, LeMans & GTO Technical Discussions 1 10-26-2009 02:34 PM
65 ignition switch asshauler 1964-1974 Tempest, LeMans & GTO Technical Discussions 4 02-25-2009 11:58 PM
Ignition Switch? 66_goat 1964-1974 Tempest, LeMans & GTO Technical Discussions 7 10-29-2007 10:13 PM
Bypassing ignition switch; 66 GTO dagold 1964-1974 GTO General Discussion 1 03-28-2005 09:33 AM
SEO by vBSEO 3.3.2
