Installing Distributor - Pontiac GTO Forum
post #1 of 6 (permalink) Old 03-31-2011, 11:10 AM Thread Starter
This may be a basic question, but I need help. Finally approaching start up dayfor my 66. It has been a frame off for about....too long! I did not mark the distributor when I pulled it, so how do I assure I am installing it correctly. Do I put the engine on TDC and install with rotor pointing at #1 on cap?
Thanks for the help.
Sloan66 is offline
post #2 of 6 (permalink) Old 03-31-2011, 12:02 PM
68GTO4004Spd's Avatar
Yes, cylinder #1 at TDC and dizzy at #1.
68GTO4004Spd is offline
post #3 of 6 (permalink) Old 03-31-2011, 03:48 PM
Quoted: 35 Post(s)
The rotor will turn as the dizzy seats. Be sure it is still lined up with the cap termainal when it's all the way in. If it won't "quite" line up, you'll need to take a long slot screwdriver and turn the oil pump drive rod a small amount. It has to be "dead nuts" on.
post #4 of 6 (permalink) Old 03-31-2011, 06:57 PM Thread Starter
Thanks, that helps.
Sloan66 is offline
post #5 of 6 (permalink) Old 03-31-2011, 09:52 PM
Quoted: 34 Post(s)
Originally Posted by Sloan66 View Post
Thanks, that helps.
Also, remember that the timing marks will indicate TDC at TWO different times: once when #1 is at TDC on the compression stroke, the other time when #1 is at TDC on the exhaust stroke. You want to line up your distributor when it's at TDC on the compression stroke, otherwise you'll have it exactly 180 degrees "out". Two ways to tell: put your thumb over the empty spark plug hole and feel/listen for pressure as you turn the engine over, or pull the valve cover on that side and watch to make sure both valves are closed with the timing marks at TDC.
Also, you didn't ask this but just in case --- factory orientation of the distributor has the vacuum advance connection on the distributor pointed more or less directly at the driver's side fender, distributor cap wired so that #1 cylinder connector is at about "half way" between the firewall and the drivers side fender. ("Pointed at" the general vicinity of the brake pedal). Remember Pontiac distributors turn counter-clockwise. If you didn't "care" about factory orientation, you could just install the distributor any old way, make sure the motor's at TDC #1 compression, see which terminal the rotor's pointing at, connect #1 plug wire there then work your way around the distributor counter-clockwise connecting the rest of the plug wires in firing order sequence. It'd work just fine --- assuming all the plug wires "reached".
post #6 of 6 (permalink) Old 04-06-2011, 06:57 PM Thread Starter
Thanks Bear, great info.
Sloan66 is offline
Human Verification
distributor Chris-Austria 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 02-23-2011 02:39 PM
distributor vacuum port cal114 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-28-2008 06:50 PM
Distributor gear 70gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 05-02-2008 11:54 AM
70 gto Distributor replacement 70gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-23-2008 06:58 PM
Distributor opinion squeezedgto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-13-2007 06:26 PM
