Intake and Carb numbers - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 09-16-2010, 09:46 PM   #1 (permalink)
I have a 67 400 HO 360 HP engine in my 67 GTO and some one placed a edelbrock intake and a Holley Street Avenger carb on it. I would like to take it back to stock and was wondering what the correct number intake and carb would be for the car. It is a four speed car. thanks Mike
mshidner is offline   Reply With Quote
Old 09-16-2010, 10:10 PM   #2 (permalink)
My Photos: (473)
The quadrajet part number for a manual tranny is 7027263 and the manifold part number is 9786286, good luck with your search.
Old 09-16-2010, 10:42 PM   #3 (permalink)
Hello Randy, thanks for the help. Where would a person find this information? Was there a difference between the low HP engine in 67 and the HO engine for the intake and carb? Also did the 67 HO Ram Air have a different intake and carb then the mid engine HO? thanks for all the help.
Old 09-17-2010, 05:37 PM   #4 (permalink)
Correct Intake
First you need to know the build date of your car. It is on the spec. plate on the firewall. Then you will need to find and intake with the matching date. It should be before the build date. For example a build date or A227 would need an intake with a date code of L156 or within 3-4 months earlier than the A227. Then you just need to get a carb with the right part number for the year. Carbs were also dated. The 400 HO had a Rochester. They get pretty pricey when all original. Hope this helps. Good Luck.
400HO is offline   Reply With Quote
Old 09-17-2010, 06:12 PM   #5 (permalink)
My Photos: (473)
Here are the 1967 part numbers for the carbs and manifolds, there were 3 HP ratings for the 67 GTO,
1967 Carburetor part numbers;
1967 Intake Manifold part numbers;
Intake and Carb numbers-67-gto-manifold.jpg   Intake and Carb numbers-67-carb-numbers.jpg
Anyone using an Edelbrock carb on a Pontiac intake? Edelbroke 1964-1974 Tempest, LeMans & GTO Technical Discussions 6 02-05-2010 09:22 PM
Intake and carb GTO'n'TRANSAM 1964-1974 Tempest, LeMans & GTO Technical Discussions 3 02-15-2009 04:51 PM
Intake and Carb GTO'n'TRANSAM 1964-1974 Tempest, LeMans & GTO Technical Discussions 9 02-02-2009 06:57 AM
New Intake - and Current Carb?? ThomasGTO 1964-1974 GTO General Discussion 5 01-23-2009 03:50 PM
CARB intake? thispecialk Intake and Exhaust Discussions 8 01-23-2009 10:19 AM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
