If the mechanic 'capped off' the distributor and doesn't know why it's running so rough, you need another mechanic. There are lots of threads on this forum that deal with tune up issues, and a lot of information on the web. Depending on your mechanical savvy, you may need to do a little or a lot of homework. Start with basics: ignition dwell, timing, carb mixture, firing order, vacuum leaks, etc.
