Old 04-26-2008, 01:25 PM   #1 (permalink)
70gto's Avatar
new timing light new question
I decided to check my 70 gto timing with a new light that has the advance dial. I run points. Well I first moved my vac advance to the manifold, and capped the carb. Checked dwell at 30 degrees. Adjusted idle to 1050 idle and about 900 in gear. I run a Ramair 4 cam so it needs a little more to idle right . By turning the timing light knob when the line hits 0 on the balancer I am at 30 degrees per the knob on the timing light. Is this about right?
I went to check it by disconnecting and plugging the vac advance but it ran real rough back fired and by the time I turned it off I fouled number 1 plug. In fact the timing light would not work with the back fireing. I pulled the plug cleaned it , checked wires and decided to call it a day. Needed to get to T ball game.
I see the tuning sticky in this thread, I followed that and one on another GTO site, I did vac check the advance it does work, and I pulled the cap and rotor to visually check it out. It is missing the bushing under neath mentioned in the sticky and runs 2 silver springs. So I just want to know how close am i with the timing at 30 degrees with vac hooked up?
Not bad for $400, it was Palladium Silver, Primer, and very tired.
70gto is offline   Reply With Quote
Old 04-26-2008, 08:38 PM   #2 (permalink)
Moderator
My Photos: (16)
If you read the sticky, Lars suggests 36* total advance @ about 2500-2800RPM. Disregard what the timing is at idle.
GTO Tuning and Setup Tips
Rukee is offline   Reply With Quote
Old 04-27-2008, 09:52 AM   #3 (permalink)
70gto's Avatar
Well he is doing it with advance disconnected, I had problems when i pulled the advance off. Plus that seems a little hi for a pontiac, I believe he is using a chevy . I was trying 32 to 34 at 2100 before the back fire , I just was curious what base idle at 30 degrees means.
Old 04-27-2008, 11:23 AM   #4 (permalink)
Moderator
My Photos: (16)
You want to check total advance with the hose on , and then just let the timing at an idle end up were ever it wants to be (as long as it starts okay without hitting hard) with the total at 36* @ 3000RPMs.
A chevy engine runs a bit more timing, total advance at about 38-40* at 3000RPMs.
trunk reel out light question abraxasil 1964-1974 GTO Restoration and Technical Discussions 0 07-06-2007 11:06 AM
Fog light question... ChiefyGTO 2004-2006 GTO General Discussion 2 11-22-2006 12:09 AM
Shift light question KC.MO.GTO Service, Maintenance and Technical Discussion 1 07-10-2006 09:45 PM
Silly question, Clock light on ? Seattle GTO Service, Maintenance and Technical Discussion 1 07-04-2005 09:58 PM
Dome Light Upon Entry Question BlackGoat Service, Maintenance and Technical Discussion 3 02-11-2005 05:51 AM
