Old 06-29-2008, 10:04 PM   #1 (permalink)
VettenGoat's Avatar
Ragged out steering joint
Can anyone shine some light on how the rag joints come out of the steering column? Working on one that is aged and painted over enough that it seems immoveable. Taking the two bolts out was easy enough, but how do the riveted stud come out? The 12 point lockbolt looks to be nearly rounded off, also adding to the adventure.
Mike
VettenGoat is offline   Reply With Quote
Old 06-30-2008, 11:54 AM   #2 (permalink)
My Photos: (2)
You need to replace the whole rag joint. Don't worry about it coming apart. Loosen the 12 point bolt at the steering column end, and see if you can wedge a slot-type screwdriver in the joint's seam to open it up so you can slide/pry it off. WD 40 helps, too. The new joint will go on without much problem. Some of the afterwarket ones (Like the one in my '67) bolt together, which helps make the install easier. Hope this helps.
Jeff
Old 06-30-2008, 06:29 PM   #3 (permalink)
My Photos: (451)
I tried the rebuild kit for my 66 and had the same problems you are having, after fighting with it for several hours I ordered a new one from Year One.
05GTO is offline   Reply With Quote
Steering wheel parts ppurfield001 1964-1974 GTO Restoration and Technical Discussions 2 06-19-2008 10:46 AM
Steering Effort tanktronic 2004-2006 GTO General Discussion 5 10-10-2007 07:02 PM
Manual steering 64 GTO lazlo Service, Maintenance and Technical Discussion 2 09-19-2007 08:54 PM
need help steering column removal 66gto 1964-1974 GTO General Discussion 4 01-03-2007 08:25 PM
65 GTO Steering Wheel fst65gto 1964-1974 GTO General Discussion 0 04-30-2005 09:44 PM
