I have been looking all over and I cant find any info on this rear end. When your looking at the rear of the vehicle this number 8LM G9208 is on the front right axle tube facing the engine. There is also a raised H with a what looks like a upside down 4 on the left side of the housing facing the engine and a raised symbol (*) and a raised C and D or a O facing the engine any help i would appreciate.
i can see you dont have a sway bar, I dont either witch leeds me to my next ? what are the two holes one on each side of the axle carrier that are below the axle looks like something bolts there
Well i can see that I have a GM 10 bolt 8.5 in my car. I looked up and i can see there was some fabricating done up to fit it in, so i guess thats good Right ???
The rear sway bar mounts onto two bolt holes in the lower suspension arms.
GTOs did not come with them cause they were made for straight line speed, not handling.
Not necessarily.......there were thousands of them installed in A bodies that would be a direct bolt in without mods. If it is from a Nova or Apollo that had leaf springs, it may not be centered correctly. Maybe it has a coil over set-up or aftermarket 4 link. It's very difficult to guess what you have without pictures to see and evaluate.
Mitch
1967 GTO; Gulf Turquoise on Black, 4 speed bench
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1970 Cevelle SS 396
1952 Chev 2 ton flat bed
1938 Chev coupe
