Old 06-22-2008, 06:16 PM   #11 (permalink)
My Photos: (451)
Originally Posted by jasin View Post
Attachment 3014
Attachment 3015
I'll measure the shock tomorrow
Problem # 1, your coil spring is upside-down. The pig tail goes on the bottom.
Problem # 2, there is a spacer that mounts on top of the spring and the car sits on the spacer .
Problem #3, The bottom item in the below picture sits on top of the pig tail and bolts to the plate on the axle.
The pig tail is the part of the spring that is smaller in diamete than the rest of the spring.
Coil spring spacer,
05GTO is offline   Reply With Quote
Old 06-23-2008, 10:26 PM   #12 (permalink)
1)Coil spring is same on top and bottem(called the company and they said install either way), I swapped it around anyway.
2)the insert/insulator is not reused, wrong size anyway, new coil not the same as oem coil(also called company and the guy said no need for it)
3)The coil spring clamp doesn't clamp down on the spring, the spring perches are not right for this spring annd clamp. Looks like they were welded on later, not oem I assume.
jasin is offline   Reply With Quote
Old 06-23-2008, 10:54 PM   #13 (permalink)
Moderator
My Photos: (16)
The springs don`t seem right. What company made them and what`s the part #?
Old 06-24-2008, 09:43 AM   #14 (permalink)
My Photos: (451)
Below are pictures of my 67 with a late 60s or early 70s type c 12 bolt rear end and pictures of the 66 with the correct rear end. The 67 has black springs and the 66 has gray springs.
Also, there is a picture of the rear original coil springs removed from the 66 which include the insulator-spacer.
Good luck,
rear-coil-spring-mounting-p1010044.jpg  rear-coil-spring-mounting-p1010047.jpg  rear-coil-spring-mounting-p1010050.jpg  rear-coil-spring-mounting-p1010051.jpg  rear-coil-spring-mounting-p1010042.jpg
Old 06-24-2008, 10:11 AM   #15 (permalink)
My Photos: (451)
Images of 67 service manual;
rear-coil-spring-mounting-p1010043.jpg  rear-coil-spring-mounting-p1010044.jpg
Old 06-24-2008, 11:05 PM   #16 (permalink)
Hotchkis is where springs are from
19930003 Rear coil, 67-72 A-body
not sure what the deal is on this thing, looks like the spring perchs were welded on the axle, think they are way different then the original
Also see there are 2 holes on the bottem shock mount, I went to move the shock up to the top one, perfect fit, but the angle didn't look right so I dropped it back down again
I just clamped the damn thing with both clamps for now, sitting on the upside down bowl of the spring perch....till I think of something else....
Thanks for the help
The GT-R Hype....... Good 2 go The Lounge 41 12-20-2007 11:06 AM
Report Prompts Investigation Into Pontiac GTO 05GTO In the News 99 06-29-2007 07:13 PM
Eibach Spring 1.0/0.8 Rear Camber? Whannanna Drive train, suspension, alignment and brakes. 1 05-01-2007 06:44 PM
cam Q's GTO6 2004-2006 GTO General Discussion 1 10-18-2006 08:34 PM
05 Spec lasstss Service, Maintenance and Technical Discussion 8 06-03-2006 12:22 AM
