remove ignition cylinder with no key????? - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Go Back   Pontiac GTO Forum > The 1964-1974 Pontiac Tempest, Lemans & GTO > 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 08-16-2009, 08:17 PM   #1 (permalink)
crustysack's Avatar
My Photos: (54)
for a 1965 gto is there any way to get the lock cylinder out of the ignition without the key- or can I get the key code from off my car somewhere?? oddly I do have the data plate- any help would be appreciated
thanks
crustysack is offline   Reply With Quote
Old 08-16-2009, 10:52 PM   #2 (permalink)
67 Basket Case Restorer
Too Many Projects's Avatar
My Photos: (27)
I had original keys made from the PHS docs. The code is on there and the dealer has to translate it and cut the key, if they have one. I had to buy keys from Ames first.
If you don't have the docs or the cylinder has already been changed, you can use a small drill bit to drill out the tumblers from the front and pull it out.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline   Reply With Quote
Old 08-17-2009, 06:23 AM   #3 (permalink)
crustysack's Avatar
My Photos: (54)
yeah i figured it was gonna be along the drill it out option- thanks
Gear in this thread - Powered by O'Reilly Auto Parts
Ignition Lock Cylinder goatcrazy88 Service, Maintenance and Technical Discussion 15 07-08-2011 05:33 PM
Remote Code Key & Theft Deterrent System GM4life Service, Maintenance and Technical Discussion 0 06-15-2008 12:13 AM
Not smooth when turning the ignition key PatrickNJ 2004-2006 GTO General Discussion 12 10-08-2007 06:32 AM
Computer guages (Autotap OBDII-CAN Diagnostic) MJGTOWISH 2004-2006 GTO General Discussion 3 12-03-2006 11:01 AM
Ignition key fail to turn over! Black_Goat Service, Maintenance and Technical Discussion 2 10-18-2005 10:30 PM
Powered by vBulletin® Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
