Sagging 67 GTO HELP! - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-25-2010, 09:34 PM Thread Starter
Hello. My 67 GTO has been in storage for 6 years. Prior to storing it I installed a set of AMES Performance rear coil springs. The car always looked low to begin with but now it seems very low. So low that when I it a bump there is a loud thump in the rear of the car. I had the car on a hoist, no exhaust banging, the tailshaft UV joint used to smack the trans tunnel but I think that is fixed. I am trying to figure out how high the rear of the car should be. Right now the center of the rear wheel well is 23 7/16 inches from the ground. I knwo tire size makes a big difference. The car has 17" wheels and 40 series tires. The springs are VERY mushy. Does anyone know of a stigffer spring that will not lower the car? That is a little cheaper tham Hotchkis or Glocal West?
Can anyone email me a copy of their spring perches on a factory 66-67 gto? I started thinking my car was cobbled together and the axel may be wrong? When I bought the car in 2001 it had helper spring around the shocks and coil springs. I replaced those with new monroe shocks...6 yrs ago.
Any help would be appreciated. Anyopne in Detroit area???
gtodetroit is offline
post #2 of 2 (permalink) Old 08-26-2010, 09:47 AM
Contact Eaton Spring. they will make springs to your needs...about $200 front and $200 rear.
Eric Animal is offline
Human Verification
Sagging Springs ROBSGTO Drive train, suspension, alignment and brakes. 36 01-02-2009 12:16 PM
sagging ass Empaler 2004-2006 GTO General Discussion 6 01-20-2006 12:59 PM
