Shifting Issue's - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Old 02-26-2013, 02:33 PM   #1 (permalink)
Shifting Issue's
Hey ya'll so my 73 GTO 1st wont start in park, have to put it in drive, someone said it was the park safety switch, any thoughts? 2nd i have no real issue shifting to drive or revers or anything BUT when i go to shift up on the shifter (on the floor) it makes almost a grindind noise, my neighbor who has a 73 Monte Carlo said it may be the linkage is off, how do I fix this?
airdale171 is offline   Reply With Quote
Old 02-26-2013, 04:42 PM   #2 (permalink)
My Photos: (12)
Put it in park, then grab the round collar on the steering wheel between the wheel and the dash and turn it with your hands to the left as far as you can. If it will start after doing that, then your problem is likely to be either that the "back drive" linkage is out of adjustment, or the neutral safety switch on the top of the lower steering column near the firewall behind the dash is out of adjustment.
The back drive linkage is a linkage from the transmission shift arm (on the transmission, where the shifter connects) to an arm on the lower end of the steering column inside the engine compartment. Moving the linkage moves the arm and rotates that collar on the column that is ultimately connected to the neutral safety switch. If the linkage is out of adjustment, then the switch with "think" that the transmission is in a different gear than it really is. If you get under the car so you can see, you'll find the linkage rod that goes to the steering column can be adjusted by loosening a clamping nut that the rod slides through. Make sure the transmission is in Park, loosen that nut, then push "up" on the rod as far as you can (rotating the collar to the left), then tightening the nut back down to lock it in there. If it's out of adjustment, that should get you close. Sometimes it takes several tries to get things lined up just right.
Garland, TEXAS
BearGFR is online now   Reply With Quote
a4 Shifting @ WOT nboost Drive train, suspension, alignment and brakes. 3 11-19-2010 05:42 AM
1st to 4th shifting on M6 Goat'n Drive train, suspension, alignment and brakes. 1 02-24-2010 09:18 PM
[b]problem With Shifting[/b] dablue06pontiacGTO 2004-2006 GTO General Discussion 8 10-13-2006 02:43 AM
Shifting The_Goat Service, Maintenance and Technical Discussion 1 03-22-2005 05:51 PM
Shifting the 6 speed zone 5 2004-2006 GTO General Discussion 25 11-07-2004 09:19 PM
SEO by vBSEO 3.3.2
