? Timing On 428 - Pontiac GTO Forum
Pontiac GTO Pontiac GTO Forum
» Auto Insurance
Wheel & Tire Center
Register Home Forum Active Topics Photo Gallery Garage Search Today's Posts Mark Forums Read Auto EscrowInsurance
Old 09-01-2009, 07:41 PM   #1 (permalink)
? Timing On 428
OK I have a 1968 gto 428. It has 11.2:1 Mid Street cam 46 428 heads 750 edelbrock carb malory dist Newly Rebuilt.
What Should I set the timing to at 4,226ft And idle?
Speed Demon All The Way
goatmaster428 is offline   Reply With Quote
Old 09-02-2009, 12:17 PM   #2 (permalink)
My Photos: (2)
With your compression, you'll need 100 octane fuel, more likely 102 or higher. Base timing should be about 6 to 8 degrees BTDC. Idle in nuetral should be about 1000 rpm, maybe a shade less. If you're running 92 octane, you'll need to run your timing about 10-15 degrees retarded---about 5-10 degrees ATDC or maybe TDC (0 degrees), and it'll be a dog.
Timing Chain play Joust 1964-1974 Tempest, LeMans & GTO Technical Discussions 3 07-07-2009 02:15 PM
Where are the timing marks on 455 HO? clarkaim 1964-1974 Tempest, LeMans & GTO Technical Discussions 2 06-19-2009 06:20 PM
428 or 455? (Do I Live Up To My Name?) Goatman455 1964-1974 GTO General Discussion 31 06-09-2009 03:49 PM
66 389 tripower timing noluck 1964-1974 Tempest, LeMans & GTO Technical Discussions 6 01-30-2009 07:32 PM
new timing light new question 70gto 1964-1974 Tempest, LeMans & GTO Technical Discussions 3 04-27-2008 11:23 AM
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
